Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5477 Cmd Rej: RQDTBLNOP must NOT be specified
For the ent/chg-srvsel command, if a value of aiq or idps is specified for the (n)serv parameter, then the (n)rqdtblnop parameter cannot be specified.
For the ent/chg-ss-appl command, if the appl=aiq parameter is specified, then the (n)rqdtblnop parameter cannot be specified.
Recovery
  1. Display the entries in the Service Selector table. Enter the rtrv-srvsel command.
    This operation can be lengthy. The Service Selector table contains over 1000 entries.
  2. Change or delete an entry as desired. Refer to the command description for the chg/dlt-srvsel commands in the Commands User's Guide and to the appropriate feature manual for assistance.
  3. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide, to the ELAP Administration and LNP Feature Activation (ss-appl commands) and to the appropriate feature manual (srvsel commands) for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
