Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2325 Cmd Rej: Alias type matches DPC type
The alias parameter must be specified with a different point code type than the dpc parameter. A specified alias type cannot already be defined as a destination address.
The aliasa and dpca parameters cannot be specified together in the command. The aliasi and dpci parameters and the aliasn and dpcn parameters cannot be specified together in the command if the prefix subfields are the same (both are spare or both are non-spare).
Recovery
  1. Display the existing alias and dpc parameter value code types. Enter the rtrv-dstn command.
  2. Re-enter the ent/chg-dstn command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
