Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4160 Cmd Rej: ACCESS parameter value is invalid for this card
The value any for the format portion of the access parameter can be specified only on IXP-based cards. The format value must be set to any on IXP-based cards.
Recovery
Re-enter the ent-bp command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
