Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2620 Cmd Rej: No optional parameters may be specified if FORCE=YES
If the force=yes parameter is specified, then the ipappl, ipport, or loc parameters cannot be specified.
Recovery
Re-enter the dlt-ip-node command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
