Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2933 Cmd Rej: A specific SI must be specified in the range (0-15)
The si parameter must be specified, and the value must be within a valid range.
Recovery
Re-enter the ent/chg/dlt-scr-sio command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
