Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2701 Cmd Rej: Meas Platform feature must be ON
The Measurements Platform feature must be turned on before the ent-card command can be entered for a type MCPM card (E5-MCPM-B).
For the chg-measopts command, the Measurements Platform feature must be turned on before the platformenable=on parameter can be specified.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
  1. Display the status of the Measurements Platform feature. Enter the rtrv-feat command.
  2. Turn on the Measurements Platform feature as necessary. Refer to the Database Administration - System Management User's Guide for assistance.
  3. Re-enter the command that generated the error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
