Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2781 Cmd Rej: NDFLTACT parameter must be FORWARD, DUPLICATE, or DUPDISC
The ndfltact parameter must have a value of forward, duplicate, or dupdisc before the nmapset, nri, and ntt parameters or the pc or ssn parameter can be specified.
Recovery
  1. Display the existing values for the parameters. Enter the rtrv-gsms-opcode command.
  2. Re-enter the chg-gsms-opcode command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
