Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5101 Cmd Rej: Maximum Opcode Quantity FAK already enabled
If the TOBR quantity feature of maximum quantity level is enabled, then no other TOBR Quantity feature can be enabled.
Recovery
Display the TOBR quantity present in the system. Enter the rtrv-ctrl-feat command.
If the maxiumum quantity is enabled, then no recovery is required.
Contact My Oracle Support for additional assistance. See My Oracle Support (MOS).
