Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5119 Cmd Rej: GTT Action-DISCARD Feature must be enabled
For the ent/chg/rtrv-gttact commands, the GTT Action - DISCARD feature must be enabled before a value of disc, udts, or tcaperr can be specified for the act parameter.
For the rtrv-gttact command, the GTT Action - DISCARD feature must be enabled before the uimreqd, atcaperr, itcaperr, or udtserr parameter can be specified.
Recovery
  1. Display the status of the GTT Action - DISCARD feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable the feature as necessary. Refer to the Database Administration - GTT User's Guide for assistance.
  3. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
