Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2705 Cmd Rej: IP Node Address never entered or Card DB corrupt
The IP address specified by the ipaddr parameter must match the IP address of the remote IP node for the card specified by the loc parameter.
Recovery
  1. Display the address of the remote IP node for the card. Enter the rtrv-ip-node:loc= command.
  2. Re-enter the ent/dlt-ip-node address that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
