Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2206 Cmd Rej: Invalid originating application ID
A valid value must be specified for the oa parameter.
Recovery
Re-enter the send-msg command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
