Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2824 Cmd Rej: Could not access standby fixed disk
A hardware problem may exist.
Recovery
  1. Dispaly the status of the standby TDM. Enter the rept-stat-db command.
  2. If the status of the standby TDM shows noaccs, contact My Oracle Support. See My Oracle Support (MOS).
  3. If the status of the standby TDM shows stdby, re-enter the copy-fta, copy-gpl, or format-disk command that generated this error message.
    Caution:
    Contact My Oracle Support before entering the format-disk command. See My Oracle Support (MOS).
