| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.7 E97329 Revision 1 |
![]() Previous |
![]() Next |
If the dir=atoi parameter is specified, then the tta parameter must be specified.
Recovery
Re-enter the chg-gtcnv command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
