Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2129 Cmd Rej: CDPNPFX must be specified
If the ncdpnpfx or dltpfx parameter is specified, then the cdpnpfx parameter must be specified.
Recovery
Re-enter the chg-inpopts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the INP/AINPQ User's Guide for assistance.
