Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3610 Cmd Rej: Failure reading VLR DBMM Table
Not able to access the VLR DBMM Table in the ent-vlr-roaming, chg-vlr-roaming, dlt-vlr-roaming, ent-vlr-prof, chg-vlr-prof, and dlt-vlr-prof commands.
Recovery
  1. The DB should be repaired or restored using the chg-db: action=repair/restore command.
  2. Re-enter the command that generated this error message.
    Contact My Oracle Support (MOS) if this error message appears again.
