| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.7 E97329 Revision 1 |
![]() Previous |
![]() Next |
The Cluster Routing and Management Diversity (CRMD) and Nested Cluster Routing (NCR) features must be turned on before the ncai parameter can be specified.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.Recovery
