Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4478 Cmd Rej: Force must be specified to inhibit the last SEAS terminal
For the inh-card command, if the card specified by the loc parameter has the last in-service SEAS Terminal configured, then the force=yes parameter must be specified to inhibit the card.
For the inh-trm command, if the terminal specified by the trm parameter is the last SEAS terminak, then the force=yes parameter must be specified to inhibit the last terminal.
Recovery
  1. Display the terminals in the system. Enter the rtrv-trm command.
  2. Configure an additional SEAS terminal if desired. Refer to the Database Administration - System Management User's Guide for assistance.
  3. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
