| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.7 E97329 Revision 1 |
![]() Previous |
![]() Next |
If the ssn=1 parameter is specified, then the scmgfid parameter must be specified.
If the ssn parameter has a value other than 1, then the scmgfid parameter cannot be specified.
Recovery
Re-enter the ent/chg/dlt/rtrv-cdpa command, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
