Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5091 Cmd Rej: TIF Number Substitution feature must be Enabled
For the ent/chg-npp-srs command, the TIF Number Substitution feature must be enabled before an Action Set containing the NSCGPN or NSCDPN Service Action can be specified.
For the chg-tifopts command, the TIF Number Substitution feature must be enabled before the nsaddldata or nspublic parameters can be specified.
Recovery
  1. Display the status of the TIF Number Substitution feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable the TIF Number Substitution feature as necessary. Refer to the TIF User's Guide for assistance.
  3. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
