Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4175 Cmd Rej: If NGTI is 4, NNP and NNAI must be specified
If the ngti=4 parameter is specified, then the nnp and nnai parameters must be specified.
Recovery
Re-enter the ent/chg-gtmod command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
