Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2525 Cmd Rej: NI,ZONE,MSA,UN or NPC must be C when creating new blocked SR
For the ent-scr-blkdpc command, when a blocked DPC screen is created, the first entry for the ni-nc-ncm, zone-area-id, or msa-ssa-sp must be c-c-c or the npc=c parameter must be specified.
For the ent-scr-blkopc command, when a blocked OPC screen is created, the first entry for the ni-nc-ncm, zone-area-id, or msa-ssa-sp must be c-c-c or the npc=c parameter must be specified.
For both commands, subsequent entries can be specific point codes.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
Contact My Oracle Support for assistance if this error message appears again. See My Oracle Support (MOS).
