Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2174 Cmd Rej: May not modify both T20 and IT22 timers
The t20 and it22 parameters cannot be specified together in the command.
Recovery
Re-enter the chg-l3t command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
