Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2709 Cmd Rej: APPL is invalid for specified PERIOD
The appl parameter can be specified only with the period=last or period=specific parameter.
Recovery
Re-enter the rept-meas command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Measurements Reference for assistance.
