Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3886 Cmd Rej: SSN/TYPE combination does not exist
The ssn/type parameter combination must already exist in the GSM SSN Screening table.
Recovery
  1. Display the entries in the GSM SSN Screening table. Enter the rtrv-gsmssn-scrn command.
  2. Re-enter the dlt-gsmssn-scrn command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
