| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.7 E97329 Revision 1 |
![]() Previous |
![]() Next |
A valid destination IPv4 or IPv6 address must be
specified as the value for the
dest or
dest6 parameter. Refer to the command description
in
Commands User's Guide for the criteria for a
valid destination IP address.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
