| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.7 E97329 Revision 1 |
![]() Previous |
![]() Next |
For the rept-stat-iptps command, if the loc parameter is specified, then the history, tpscost, or peakreset parameter must be specified.
Recovery
Re-enter the rept-stat-iptps command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and the Database Administration - IP7 User's Guide for assistance.
