| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.7 E97329 Revision 1 |
![]() Previous |
![]() Next |
The type=gtwy and enttype=origninc parameters must be specified before the nc parameter can be specified.
Recovery
Re-enter therept-meas command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Measurements Reference for assistance.
