Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2474 Cmd Rej: Translation TYPE must be specified
If the alias parameter is specified, then the type/typea/typei/typen/typen24/typeis/typens parameter must be specified.
Recovery
Re-enter the dlt-tt command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
