Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2721 Cmd Rej: Integer value must be less than 65535
For 80286 processors, integer values for registers and conditions must be less than 65535.
Recovery
Re-enter the ent-bp command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
