Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2985 Cmd Rej: Application ID not supported
The value of the APPLID parameter is fixed and cannot be changed.
Recovery
  1. Re-enter the command that generated this error message without specifying the APPLID parameter.
    Refer to the command description in Commands User's Guide and Database Administration - Features User's Guide for assistance. Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
