Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2534 Cmd Rej: No match on NCM parameter during retrieve
The value specified for the ncm parameter must already exist.
Recovery
  1. Display the current values for the parameters. Enter the command that generated this error message, specifying only the all=yes parameter.
  2. Provision new values as necessary. Refer to the Database Administration - GWS User's Guide for assistance.
  3. Re-enter the command that generated this error message, specifying a valid combination of parameters.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
