| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.7 E97329 Revision 1 |
![]() Previous |
![]() Next |
A timer value and the SRCTSET parameter should not be specified together.
Recovery
Re-enter the chg-m2pa-tset command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
