Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2503 Cmd Rej: NC cannot be zero when NI is less than 6
If the value specified for the ni parameter is less than 6, then a value of 0 cannot be specified for the nc parameter.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
