Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5104 Cmd Rej: DIALPFX must be specified
If the ndialpfx or dltpfx parameter is specified, then the dialpfx parameter must be specified.
Recovery
Re-enter the chg-ainpopts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the INP/AINPQ User's Guide for assistance.
