Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3367 Cmd Rej: DRA with NEC and NEC=NONE combination not allowed
If the nec=none parameter is specified, then values of asdrnnecdn, rnasdnecdn, rnnecdn, rngrnnecdn, and grnrnnecdn cannot be specified for the dra parameter.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the Commands User's Guide and the INP/AINPQ User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
