| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.7 E97329 Revision 1 |
![]() Previous |
![]() Next |
The allowed maximum is 1 connection per signaling link on IPLIMx cards.
Recovery
rtrv-assoc command to see the SLK configured for the association under consideration.chg-assoc command to configure an association with a unique SLK and socket combination.Refer to the command description in Commands User's Guide for assistance.
If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
