Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2573 Cmd Rej: SR or NSR does not reference an existing SR
The screening reference specified by the sr or nsr parameter does not exist.
Recovery
  1. Display the screening references in the entity set. Enter the rtrv- for the associated command. Refer to the command description in Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
