Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3699 Cmd Rej: EIR feature must be ON
For the ent/chg/dlt-ss-appl commands, the Equipment Identity Register (EIR) feature must be turned on before the appl=eir parameter can be specified.
For the chg-gsmopts command, the EIR feature must be turned on before the eirgrsp, eirsptype, or eirimsichk parameter can be specified and before the eirimsichk option can be specified for the on or off parameter.
For the ent/chg-map commands, the EIR feature must be turned on before a true point code value for the pci or mpci parameter can be specified
For the chg-mtc-measopts command, the EIR feature must be turned on before the mtcdeir=on or mtcheir=on parameter can be specified
For the chg-sid command, the EIR feature must be turned on before the cpctype=eir parameter can be specified
For the ent/chg-srvsel commands, the EIR feature must be turned on before the (n)serv=eir parameter can be specified
For the ent-trace command, the EIR feautre must be turned on before the imei parameter can be specified.
For the rept-ftp-meas command, the EIR feature must be turned on before the enttype=eir parameter can be specified.
Recovery
  1. Display the status the EIR feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable and turn on the EIR feature as necessary. Refer to Commands User's Guide and EIR User's Guide for assistance.
  3. Re-enter the command that generated this error message.
    Contact My Oracle Support if the error message appears again. See My Oracle Support (MOS).
