Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4785 Cmd Rej: RLOC and LINK parameter combination must be specified
If the action=disp and tbl=lnk parameters are specified, then the rloc and link parameters must be specified.
Recovery
Re-enter the dbg-ddb command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
