Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2357 Cmd Rej: Linkset is unequipped
The value specifeid for the lsn parameter must already exist in the Linkset table and must be equipped.
Recovery
  1. Display the linksets in the database. Enter the rtrv-ls command.
  2. Re-enter ent/chg/dlt/rtrv-rte command that generated this error message, specifying a valid combination of parameters. Refer to command description in Commands User's Guide, the Database Administration - SS7 User's Guide, or the Database Administration - IP7 User's Guide for assistance.
