Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2422 Cmd Rej: ALL=YES must be specified to delete all SSNs for a PC
To delete all subsystem numbers for a given point code, the all=yes parameter must be specified.
Recovery
Re-enter the dlt-map command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
