Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2323 Cmd Rej: Terminals 1-16 cannot be set to TYPE=TELNET
If a value from 1 - 16 is specified for the trm parmaeter, then the type=telnet parameter cannot be specified.
Recovery
Re-enter the chg-trm command that generated this error message specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
