Go to primary content
Oracle® Communications EAGLE Database Administration - System Management User's Guide
Release 46.7
E97336 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
SLIC 64-bit to 32-bit Conversion
The following procedure is used to convert the 64-bit mode to 32-bit. The target card should already be running on the BLSLC64 GPL. Skip this procedure if the card is already running the BLSLC32 GPL.
  1. Inhibit the target card with the inh-card:loc=<card_loc>:force=yes.
    The card will boot and return to state OOS-MT-DSBLD within 60 seconds.
  2. Flash the card with the init-flash:loc=<card_loc>:code=appr:gpl=BLSLC32 command.
    After the flashing operations complete, the card will boot and return to state OOS-MT-DSBLD.
  3. Activate the new BLSLC32 GPL with the act-flash:loc=<card_loc> command.
    The card will now run on 32-bit mode and will accept 32-bit mode applications from the OAM.
  4. A card previously running on the BLSLC64 should already be using the correct bootloader. If in doubt, update/verfiy the SLIC bootloader with the init-flash:loc=<card_loc>:mode=rplcebl:bits=64 command.
    If the card was already running with the desired bootloader, the command has no effect; otherwise, the bootloader will be updated.
