| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.7 E97336 Revision 1 |
![]() Previous |
![]() Next |
A GPL is the software that is loaded onto a card that allows the various features in the EAGLE to work. The EAGLE currently uses the following GPLs:
Managing GPLs
Managing these GPLs consists of loading them onto the EAGLE from a removable media, downloading these GPLs to the appropriate cards in the EAGLE, then allowing the cards to run these GPLs. The GPLs can be in one of two states, trial and approved.
Refer to the Maintenance and Administration Subsystem section for more information about the control cards.The approved GPL is the GPL that has been approved for use and the EAGLE should be running, unless otherwise advised by Oracle technical support. The approved GPL version number matches the version number of the GPL contained in the system release ID table.
A trial GPL is usually a duplicate of the approved GPL; it can also be a GPL that has not been approved for use and does not match with the version number in the system release ID table. The trial GPL is a GPL that the EAGLE should normally not be running.
The system release ID table contains the version numbers
of the approved GPLs that the EAGLE should be running. The system release ID
table is contained on the E5-TDMs (Terminal Disk
Modules) and on the removable media containing the GPLs that are being loaded
onto the EAGLE. The GPLs are loaded onto the EAGLE from a removable media. To
get the GPLs from the removable media onto the EAGLE in the approved state, two
commands are used,
chg-gpl and
act-gpl.
CHG-GPL Command
The
chg-gpl command copies a GPL from the
removable media to the E5-TDMs. The new GPL becomes the trial version on each
of the E5-TDMs. This command also copies the system release ID table from the
chg-gpl command uses these parameters.
gpl – the GPL being
ver – the version
number of the GPL
audit – Specifies
whether the active
MASP system release
version is to be audited every 90 seconds.
src – Specifies the
source drive containing the GPL that is being copied. This parameter has two
values.
remove – the
removable media flash drive on the E5-MCAP card.
usb – This parameter
is to be used by Oracle personnel only and cannot be used with the
chg-gpl command.
If you are loading a GPL onto the EAGLE, the
gpl and
ver parameters must be specified with
the
chg-gpl command and a removable media
containing the GPL being loaded must be in the removable media drive on the
E5-MCAP card of the active MASP.
The
audit parameter is required only when
turning the GPL auditing on or off.
ACT-GPL Command
The
act-gpl command changes the state of
the trial GPL from “trial” to “approved.” This is also referred to as
activating the GPL. The state of the previously approved GPL is changed from
“approved” to “trial.”
The version of the GPL shown in the
RELEASE column of the
rtrv-gpl output (the GPL version in
the system release ID table) is updated to the new approved version when this
command is performed.
The
act-gpl command uses these parameters:
gpl – the GPL being
ver – the version
number of the GPL
Displaying GPL Information
Two commands can be used to display the GPL information
in the database,
rept-stat-gpl and
rtrv-gpl. The
rept-stat-gpl command shows the
versions of the GPLs that are running on the cards in the EAGLE. The
rtrv-gpl command shows the versions of
the GPLs contained on the fixed disks.
REPT-STAT-GPL Command
The
rept-stat-gpl command output contains
these five columns and displays this information.
GPL – The GPLs
contained on the TDMs (Terminal Disk Modules). The TDMs contain the fixed
disks.
CARD – The cards
that are running the GPLs
RUNNING – The
version number of the GPLs the cards are running
APPROVED – The
version numbers of the approved GPLs
TRIAL – The version
numbers of the trial GPLs
The following is an example of the
rept-stat-gpl command output.
rept-stat-gpl:loc=1103
tklc9010801 16-09-07 00:21:39 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
GPL CARD RUNNING APPROVED TRIAL
SS7HC 1103 139-010-000 139-010-000 139-010-000
BLMCAP 139-010-000 139-010-000 085-009-009
Command Completed.
The example
rept-stat-gpl output shows that the
card in slot 1103 is running the SS7HC GPL, version number 139-010-000, which
is also the approved version of the SS7HC GPL. The trial version number of the
SS7HC GPL is also 139-010-000.
You can display all the GPLs used by all the cards in the EAGLE except the flash (or communication) GPLs, a specific GPL, or all application and flash GPLs used by all the cards in the EAGLE. The flash GPLs are the BLMCAP, BLDC32, BLDC64, BLSLC32, BLSLC64, BLSLC932, and HIPR2 GPLs. The application GPLs are the other GPLs in the EAGLE.
If you specify the
rept-stat-gpl command with no
parameters, all the GPLs on all the cards in the EAGLE are displayed except for
the communication GPLs, as shown in this example.
tklc9010801 16-09-07 00:22:18 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
OAMHC 1113 139-010-000 139-010-000 139-010-000
OAMHC 1115 139-010-000 139-010-000 139-010-000
SS7HC 1104 139-010-000 139-010-000 139-010-000
SS7HC 1107 139-010-000 139-010-000 139-010-000
SS7HC 1108 139-010-000 139-010-000 139-010-000
SS7HC 1203 139-010-000 139-010-000 139-010-000
SS7HC 1207 139-010-000 139-010-000 139-010-000
SS7HC 1208 139-010-000 139-010-000 139-010-000
SS7HC 1213 139-010-000 139-010-000 139-010-000
SS7HC 1303 139-010-000 139-010-000 139-010-000
SS7HC 1304 139-010-000 139-010-000 139-010-000
SS7HC 1307 139-010-000 139-010-000 139-010-000
SS7HC 1308 139-010-000 139-010-000 139-010-000
SS7HC 1313 139-010-000 139-010-000 139-010-000
SS7HC 1314 139-010-000 139-010-000 139-010-000
GLSHC 1102 139-010-000 139-010-000 139-010-000
ATMHC 2102 139-010-000 139-010-000 139-010-000
ATMHC 3306 139-010-000 139-010-000 139-010-000
ATMHC 6101 139-010-000 139-010-000 139-010-000
ATMHC 6102 139-010-000 139-010-000 139-010-000
IPSG 1101 139-010-000 139-010-000 139-010-000
IPSG 1105 139-010-000 139-010-000 139-010-000
IPSG 1106 139-010-000 139-010-000 139-010-000
IPSG 1201 139-010-000 139-010-000 139-010-000
IPSG 1211 139-010-000 139-010-000 139-010-000
IPSG 1301 139-010-000 139-010-000 139-010-000
IPSG 1305 139-010-000 139-010-000 139-010-000
IPSG 1306 139-010-000 139-010-000 139-010-000
MCPHC 1212 139-010-000 139-010-000 139-010-000
MCPHC 5302 139-010-000 139-010-000 139-010-000
ENUM64 2305 139-010-000 139-010-000 139-010-000
ENUM64 3105 139-010-000 139-010-000 139-010-000
ENUM64 3115 139-010-000 139-010-000 139-010-000
ENUM64 3117 139-010-000 139-010-000 139-010-000
DEIR64 3215 139-010-000 139-010-000 042-010-003
DEIR64 3217 139-010-000 139-010-000 042-010-003
DEIR64 3315 139-010-000 139-010-000 042-010-003
Command Completed.
If a specific GPL, including the communication GPLs, is
specified, then all the cards running that GPL are displayed. For example, if
the
rept-stat-gpl:gpl=ss7hc command is
entered, then all cards running the SS7HC GPL are displayed as shown in the
following example.
tklc9010801 16-09-07 00:22:40 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
Command Completed.
If a communication GPL (BLMCAP ) is specified with the
rept-stat-gpl command, for example,
rept-stat-gpl:gpl=blmcap, then all
cards running the communication GPL are displayed. In the following example,
all the cards running the BLMCAP GPL are displayed as the output for the
rept-stat-gpl:gpl=blmcap command.
eagle1 16-09-09 18:53:40 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
BLMCAP 1101 138-022-000 ALM 139-002-000 139-002-000
BLMCAP 1102 138-011-000 ALM 139-002-000 139-002-000
BLMCAP 1112 139-001-000 ALM 139-002-000 139-002-000
BLMCAP 1205 138-011-000 ALM 139-002-000 139-002-000
BLMCAP 1206 138-011-000 ALM 139-002-000 139-002-000
BLMCAP 1207 139-010-000 ALM 139-002-000 139-002-000
Command Completed.
If the
display=all parameter is specified
with the
rept-stat-gpl command, then all GPLs,
application and communication GPLs used by all the cards in the EAGLE are
displayed as shown in these examples.
This example shows the output when the
display=all parameter is specified. IMT and
application GPL information is shown.:
tekelecstp 18-01-18 21:30:11 EST EAGLE 46.5.1.5.0-73.10.0
rept-stat-gpl:display=all
Command entered at terminal #18.
Command Accepted - Processing
GPL Auditing ON
OAMHC 1113 033-010-001 033-010-001 ----------- *
BLMCAP 033-010-001 033-010-001 033-010-001
OAMHC 1115 033-010-001 033-010-001 ----------- *
HIPR2 1109 141-003-000 ALM 143-005-000 143-005-000
HIPR2 1110 141-003-000 ALM 143-005-000 143-005-000
SFAPP 1103 009-011-001 009-011-001 033-010-000
BLDC64 143-006-000 ALM 000-000-000 033-010-001
SS7HC 1106 033-010-000 033-010-000 033-010-000
BLMCAP 077-005-000 ALM 033-010-001 033-010-001
IPSHC 1112 033-010-000 033-010-000 033-010-000
BLIXP 077-005-000 ALM 033-010-001 033-010-001
SCCP64 1107 033-010-000 033-010-000 033-010-000
BLDC64 064-011-000 ALM 000-000-000 033-010-001
Command Completed.
Command Executed
If the
loc parameter is specified with the
rept-stat-gpl command, all the GPLs
running on the specified card are displayed. For HC MIMs, this includes all
non-activated flash GPLs, as shown in the following example.
eagle1 16-09-09 18:52:13 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
SS7HC 1102 139-006-000 139-006-000 139-008-000
BLMCAP 139-002-000 + 139-002-000 139-002-000
Command Completed.
Notes:
The
display=all,
gpl, and
loc parameters cannot be specified in
the same command.
If GPL auditing is on, a minor alarm is generated, and
ALM is displayed for each GPL in the
RUNNING column whose version does not
match the version of the GPL shown in the system release ID table. The GPL
versions in the system release ID table are shown in the
rtrv-gpl command output.
If GPL auditing is
off, the minor alarm is not generated,
but
ALM is displayed for each GPL whose
version does not match the version of the GPL shown in the system release ID
table. The detection, marking, and reporting of corrupt GPLs continues to be
performed and is not affected by turning GPL auditing off.
If a GPL is not found, a version of “-----------” is displayed.
If a card is inhibited, “-----------” is displayed in the
RUNNING column.
A plus (+) symbol appears in the output when any of the
communication or flash GPLs are specified for the
rept-stat-gpl command. The plus symbol
indicates that the specified GPL currently running on the card has not yet been
activated on the card.
RTRV-GPL Command
The
rtrv-gpl command output contains these
six columns and displays this information.
GPL – The GPLs
contained on the TDMs.
CARD – The card
location of the TDMs, either card locations 1114 or 1116
RELEASE – The
APPROVED – The
TRIAL – The version
REMOVE TRIAL – The
version number of the GPLs contained on the removable media. Entries in the
REMOVE TRIAL column are shown only
if the removable media is inserted into the removable media drive. If the
removable media is not inserted in an E5-MCAP card, dashes are shown in the
REMOVE TRIAL column. Dashes are
displayed in the
RELEASE,
APPROVED, and
TRIAL columns.
For E5-based control cards installed in the EAGLE
installed in the E5-MCAP card of the active MASP (card location 1113), the
rtrv-gpl command output. In this
example, removable media is installed in the E5-MCAP card of the active MASP
(card location 1113), shown by the GPL version number in the
REMOVE TRIAL column for card location
1114. Removable media is not installed in the E5-MCAP card of the standby MASP
(card location 1115), shown by the dashes in the
1116.
tklc9010801 16-09-07 00:26:49 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL
SS7HC 1114 139-010-000 139-010-000 139-010-000 139-010-000
SS7HC 1116 139-010-000 139-010-000 139-010-000 -----------
SS7HC 1113 ----------- ----------- ----------- -----------
You can display all the GPLs in the EAGLE or a specific GPL in the EAGLE.
If you specify the
rtrv-gpl command with no parameters,
all the GPLs in the EAGLE are displayed as shown in this example. This is an
example of the
rtrv-gpl output when E5-based control
cards are installed in the EAGLE:
tklc9010801 16-09-07 00:28:42 EST EAGLE 46.4.0.0.0-69.10.0
GPL Auditing ON
BLMCAP 1114 139-010-000 139-010-000 085-009-012 085-009-012
BLMCAP 1116 139-010-000 139-010-000 085-009-012 085-009-012
BLMCAP 1113 ----------- ----------- ----------- -----------
OAMHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
OAMHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
OAMHC 1113 ----------- ----------- ----------- -----------
HIPR2 1114 139-009-000 139-009-000 139-009-000 139-009-000
HIPR2 1116 139-009-000 139-009-000 139-009-000 139-009-000
HIPR2 1113 ----------- ----------- ----------- -----------
SS7HC 1116 139-010-000 139-010-000 139-010-000 139-010-000
GLSHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
GLSHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
GLSHC 1113 ----------- ----------- ----------- -----------
SCCP64 1114 139-010-000 139-010-000 139-010-000 139-010-000
SCCP64 1116 139-010-000 139-010-000 139-010-000 139-010-000
SCCP64 1113 ----------- ----------- ----------- -----------
ERTHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
ERTHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
ERTHC 1113 ----------- ----------- ----------- -----------
IPSHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
IPSHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
IPSHC 1113 ----------- ----------- ----------- -----------
ATMHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
ATMHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
ATMHC 1113 ----------- ----------- ----------- -----------
IPSG 1114 139-010-000 139-010-000 139-010-000 139-010-000
IPSG 1116 139-010-000 139-010-000 139-010-000 139-010-000
IPSG 1113 ----------- ----------- ----------- -----------
PKTGHC 1114 169-010-000 169-010-000 169-010-000 169-010-000
PKTGHC 1116 169-010-000 169-010-000 169-010-000 169-010-000
PKTGHC 1113 ----------- ----------- ----------- -----------
BLMCAP 1114 139-010-000 139-010-000 085-009-009 139-010-000
BLMCAP 1116 139-010-000 139-010-000 085-009-009 139-010-000
MCPHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
MCPHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
MCPHC 1113 ----------- ----------- ----------- -----------
SIPHC 1114 139-010-000 139-010-000 139-010-000 139-010-000
SIPHC 1116 139-010-000 139-010-000 139-010-000 139-010-000
SIPHC 1113 ----------- ----------- ----------- -----------
DEIR64 1114 139-010-000 139-010-000 139-010-000 139-010-000
DEIR64 1116 139-010-000 139-010-000 139-010-000 139-010-000
DEIR64 1113 ----------- ----------- ----------- -----------
ENUM64 1114 139-010-000 139-010-000 139-010-000 139-010-000
ENUM64 1116 139-010-000 139-010-000 139-010-000 139-010-000
ENUM64 1113 ----------- ----------- ----------- -----------
PKTG64 1114 169-010-000 169-010-000 169-010-000 169-010-000
PKTG64 1116 169-010-000 169-010-000 169-010-000 169-010-000
PKTG64 1113 ----------- ----------- ----------- -----------
BLDC64 1114 139-010-000 139-010-000 085-009-006 139-010-000
BLDC64 1116 139-010-000 139-010-000 085-009-006 139-010-000
BLDC64 1113 ----------- ----------- ----------- -----------
BLSLC32 1114 139-010-000 139-010-000 085-009-009 139-010-000
BLSLC32 1116 139-010-000 139-010-000 085-009-009 139-010-000
BLSLC32 1113 ----------- ----------- ----------- -----------
BLSLC64 1114 139-010-000 139-010-000 042-010-003 139-010-000
BLSLC64 1116 139-010-000 139-010-000 042-010-003 139-010-000
BLSLC64 1113 ----------- ----------- ----------- -----------
SIP64 1114 139-010-000 139-010-000 139-010-000 139-010-000
SIP64 1116 139-010-000 139-010-000 139-010-000 139-010-000
SIP64 1113 ----------- ----------- ----------- -----------
DEIR64 1114 139-010-000 139-010-000 042-010-003 139-010-000
DEIR64 1116 139-010-000 139-010-000 042-010-003 139-010-000
Command Executed
In this example, removable media is installed in both MASPs.
If a specific GPL is specified, then only that GPL is
displayed. For example, if the
rtrv-gpl:gpl=ss7hc command is entered,
then only the SS7HC GPL is displayed as shown in the following example.
eagle1 16-09-12 12:03:53 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
ALM is displayed for each approved GPL
version that does not match the GPL version shown in the
RELEASE column. If GPL auditing is
but
ALM is displayed for each GPL version
RELEASE column. The detection,
marking, and reporting of corrupt GPLs continues to be performed and is not
affected by turning GPL auditing off. The GPL version shown in the
RELEASE column is updated when the
act-gpl command is performed.
Loading a GPL onto the System
This section gives a general overview as to how a GPL is
loaded onto the EAGLE to be used by the applicable cards. The requirements and
steps for each GPL are different and are detailed in the procedures contained
in this chapter. The
rtrv-gpl examples shown in this
section are examples that are shown when E5-based control cards are installed
in the EAGLE.
A removable media is inserted into the removable
media drive on the E5-MCAP card of the active MASP. If a specific GPL is
displayed with the
rtrv-gpl command, for example the
SS7HC GPL, the following would be displayed.
eagle1 16-09-09 18:30:48 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
SS7HC 1114 139-006-000 139-006-000 139-004-000 -----------
SS7HC 1116 139-006-000 139-006-000 139-004-000 139-008-000
SS7HC 1115 ----------- ----------- ----------- -----------
Command Executed
Displaying the SS7HC GPL with the
rept-stat-gpl command would
display all the cards running the SS7HC GPL, as shown in this example.
eagle1 16-09-09 18:31:17 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
SS7HC 1102 139-006-000 139-006-000 139-004-000
SS7HC 1205 139-006-000 139-006-000 139-004-000
SS7HC 1206 139-006-000 139-006-000 139-004-000
SS7HC 1207 139-006-000 139-006-000 139-004-000
Command Completed
chg-gpl command is executed, the
specific GPL is copied from the removable media to the fixed disks. The
specific GPL and the version number of the GPL on the removable media must be
specified with the
chg-gpl command. The version number
is found in the
REMOVE TRIAL column of the
rtrv-gpl output. For this example
the
chg-gpl :gpl:SS7HC:ver=139-008-000
command would be entered at the EAGLE terminal.
The new version of the GPL is now the trial version
of the GPL as shown in the examples of the
rtrv-gpl and
rept-stat-gpl outputs.
rtrv-gpl:gpl=ss7hc
eagle1 16-09-09 18:33:48 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
SS7HC 1114 139-006-000 139-006-000 139-008-000 -----------
SS7HC 1116 139-006-000 139-006-000 139-008-000 139-008-000
eagle1 16-09-09 18:34:26 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
SS7HC 1205 139-006-000 139-006-000 139-008-000
SS7HC 1206 139-006-000 139-006-000 139-008-000
SS7HC 1207 139-006-000 139-006-000 139-008-000
Command Completed.
To make the trial version of the GPL the approved
version, the
act-gpl command is executed after
the GPL has been copied from the removable media with the
chg-gpl command (steps 1 to 3).
The trial and approved versions of the specific GPL are swapped as shown in
these
rtrv-gpl and
rept-stat-gpl output examples.
rtrv-gpl:gpl=ss7hc
eagle1 16-09-09 18:35:31 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
SS7HC 1114 139-008-000 139-008-000 139-006-000 -----------
SS7HC 1116 139-008-000 139-008-000 139-006-000 139-008-000
The system release ID table is updated with the
version of the GPL specified with the
act-gpl command. This GPL version
is shown in the
rtrv-gpl output after the
The
ALM indicator is not displayed in
the
rtrv-gpl output because the
approved version of the GPL matches the version in the system release ID table.
eagle1 16-09-09 18:35:52 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
SS7HC 1102 139-006-000 ALM 139-008-000 139-006-000
SS7HC 1205 139-006-000 ALM 139-008-000 139-006-000
SS7HC 1206 139-006-000 ALM 139-008-000 139-006-000
SS7HC 1207 139-006-000 ALM 139-008-000 139-006-000
Command Completed.
The
ALM indicator is displayed for the
cards that are running the version of the GPL that does not match the version
in the system release ID table (shown in the
rtrv-gpl output). In this example,
the cards are running the trial version which does not match the version in the
To load the card with the new version of the
application GPL, the card must be inhibited with the
inh-card command, then placed back
into service with the
alw-card command. To load the
approved version of the GPL onto the card, the
code=appr parameter can be
specified with the
alw-card command. It is not
necessary to specify the
code=appr parameter to load the
approved version of the GPL. Entering the
alw-card command without the code
parameter loads the approved version of the GPL onto the card.
If you wish to load the trial version of the GPL
onto the card, the
code=trial parameter must be
specified with the
alw-card command.
To load the card with the new version of the flash
inh-card command and flashed with
the
init-flash command. The new flash
GPL on the card should be activated with the
act-flash command and then placed
back into service with the
alw-card command.
The following examples show the outputs of the
rtrv-gpl and
rept-stat-gpl commands after the
card has been reloaded. The outputs will vary depending on whether or not the
new version of the GPL has been made the approved version with the
act-gpl command, and which version
(trial or approved) of the GPL is loaded onto the card.
Example 1
The new GPL is the
APPROVED version and the card 1102
was reloaded with the
APPROVED version of the GPL. Card
1102 is now running the
APPROVED and
RELEASE versions of the GPL. The
ALM indicator is not shown in the
rtrv-gpl output and is not shown
for card 1102 in
rept-stat-gpl output. The
ALM indicator is shown for cards
1205, 1206, and 1207 because they are not running the
RELEASE version of the GPL.
RTRV-GPL Output
eagle1 16-09-09 18:36:26 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
REPT-STAT-GPL Output
eagle1 16-09-09 18:38:34 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
SS7HC 1102 139-008-000 139-008-000 139-006-000
Command Completed.
Example 2
The new GPL is the
TRIAL version of the GPL. The card
is now running the
TRIAL version of the GPL which is
not the
RELEASE version of the GPL. The
rtrv-gpl output, but is shown for
all the cards in
rept-stat-gpl output because they
are not running the
RTRV-GPL Output
eagle1 16-09-09 18:41:06 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
eagle1 16-09-09 18:41:59 MST EAGLE 46.4.0.0.0-69.8.0
GPL Auditing ON
Command Completed.
Example 3
The new GPL is the
TRIAL version and the card 1102
TRIAL version of the GPL. Card
TRIAL version of the GPL, but not
the
RELEASE version of the GPL has not
changed. The
1102 in the
rept-stat-gpl output because card
1102 is not running the
RTRV-GPL Output
eagle1 16-09-09 18:43:39 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
eagle1 16-09-09 18:44:12 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
SS7HC 1102 139-008-000 ALM 139-006-000 139-008-000
Command Completed.
Example 4
The new GPL is the
APPROVED version of the GPL which
is the
rtrv-gpl output, and for all the
cards in
are running the
RTRV-GPL Output
eagle1 16-09-09 18:46:20 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
eagle1 16-09-09 18:46:41 MST EAGLE 46.4.0.0.0-69.6.0
GPL Auditing ON
Command Completed
