Configure User Groups
A user group is a logical collection of users grouped together to access common information or perform similar tasks in SDM. The default LIAdministrators, administrators, provisioners, and monitor user groups are provided in SDM for you, or you can add new user groups so that you have the flexibility to define specific privileges for them based on the unique needs of your users. You can also map a local default user group or a local user group that you add in SDM to an external domain user group provided by RADIUS or LDAP authentication so that the external group can inherit the authorization privileges of the local user group.
Add a User Group
You can add a user group to which you assign users later. Those users in turn, inherit the group-based privileges that you copy from default user groups.
  1. Expand the Security Manager slider and select User management, Groups.
  2. In the User Groups pane, click Add to add a new user group.
  3. In the Add Group dialog box, complete the following fields:
  4. Click OK.
  5. In the success dialog box, click OK.
  6. Click Back to return to the User Groups table.
Delete a User Group
  2. In the Groups pane, choose the (non-default) user group that you want to delete from the User Groups table and click Delete.
  3. In the Delete confirmation dialog box, click Yes to delete this user group.
    The user group is removed from the User Groups table.
  4. In the success dialog box, click OK.
