Access Session Delivery Manager GUI Elements
The following figure shows the main SDM GUI elements:
Figure 2-1 SDM GUI
- Menu bar—Use this GUI element to access features on the Tools, Settings, and Help menus.
- Slider—Access Session Element Manager FCAPS applications: Dashboard Manager, Device Manager, Security Manager, Configuration Manager, Fault Manager, Performance Manager and the Report Manager and Route Manager applications. If you are installing SDM for the first time, the Device Manager, Security Manager, Fault Manager sliders appear only before any plugins are installed.
- Folder node—Use this node to access slider leaf nodes.
- Leaf node—Use this node to access slider application features.
- Pane—The place where slider application features are viewed, accessed, and configured.
Tools Menu
Use the
Tools menu to access
the following selections:
- Passwords—Change the password you used to login to the SDM GUI. Refer to the Change Your User Password section in this chapter for more information.
- Health Monitor—View the health of each SDM system. Refer to the Monitor Session Delivery Manager Server Health and Disk Usage chapter for more information.
- Upload configuration schema file— A configuration schema provides a configuration model and information for a device. Refer to the Configuration Manager chapter in your Oracle Communications Session Element Manager User Guide plugin product documentation for more information about uploading a configuration schema file for a device.
- Server Diagnostics—Use this selection to view SDM server log information including how log data is collected. Refer to the Use Server Diagnostic Logs section for more information.
- Device association information—Use this selection to see how many devices are in use by the product plugin and its associated applications.
- Certificates—The SDM server can use trusted certificates (certificates validated by a CA or self-signed certificate) in its trust store. Refer to the Manage Transport Layer Security Certificates chapter for more information.
- Plugin Management— Upload and install a plugin product application, such as an element manager (EM). Refer to the Manage Product Plug-ins chapter for more information.
Settings Menu
Use the Settings menu to access the following selections:
- Faults—Configure faults, fault notifications, trap receivers and heartbeat traps.
- Alarms—Configure audible alarms, alarm colors, and configure how alarms are displayed in SDM.
- Edit Login Banner—If you have full administrative privileges, you can define the informational banner seen when a user logs into SDM. This banner can also be specified to contain a user compliance rule with terms and conditions regarding the use of the application.
