Audit Logs
You can use the audit log (containing audit trails) generated by SDM to view performed operations information, which includes the time these operations were performed, whether they were successful, and who performed them when they were logged into the system.
Audit logs contain different information depending on its implementation.Audit trails include the following information:
- The user who performed the operation.
- What operation was performed by the user.
- When the operation was performed by the user.
- Whether the operation performed by the user was successful or failed.
View and Save an Audit Log
The audit log tracks user-initiated events. The following list describes some examples of user events that are audit logged in SDM:
- User logins and logouts.
- Managed devices are added.
- Device groups are added.
- Oracle Communications Session Delivery products are loaded.
- An element is added, deleted, or modified.
- A device is rebooted.
- Configurations are saved or activated.
Schedule Audit Log Files to be Purged Automatically
- Expand the Security Manager slider and select Audit log, Purge.
- In the Purge audit logs pane, specify the number of days of audit logs that are kept in the Interval in days field.
- Click Apply.
Purge Audit Log Files Manually
- In the Manual Audit log purge dialog box, click the calendar icon next to the Purge audit log records prior to field and choose the date from the calendar prior to which you want audit logs purged.
- Click OK.
