Session Delivery Manager Application Overview
Once
Oracle Communications Session Delivery Manager is installed, you can access the following features through
their respective sliders:
- Device Manager—Use this slider to configure device groups. The functionality of this slider is dependant on the product plug-in(s) that you have installed.
- Security Manager—Use this slider to configure any security privileges that are specific to SDM and the product plugin.
- Fault Manager—View events, alarms, and trap summary data.
Other sliders, such as the Device Manager, Configuration Manager, Performance Manager, and so on, are not displayed until you install a product plug-in.
