Disable the Default HTTP Daemon If your Oracle Communications Session Delivery Manager server is running a default HTTP daemon (HTTPD) process, disable that process from restarting. Login to the server as the root user. To discover if the HTTPD is installed or running: service httpd status The following message appears if the HTTPD is not installed. Continue to the next sections. httpd: unrecognized service The following message appears if the HTTPD is installed but not running. Continue to the next sections. httpd is stopped A message similar to the following appears if the HTTPD is installed and running: httpd (pid 5644) is running... If the HTTPD is running, stop the HTTPD: service httpd stop Disable the HTTPD from restarting when the system reboots: chkconfig httpd off Verify that the HTTPD is not running: service httpd status Note:If your are using Oracle Linux 7 or later, use the following command: systemctl status httpd
