Configure the NNCentral Account
For security reasons, you must create an NNCentral user account named nncentral and an NNCentral group named nncentral on the server to administer Oracle Communications Session Delivery Manager related server operations. You also must specify limited sudo privileges for the nncentral user and nncentral group. After the Oracle Communications Session Delivery Manager installation, all the installed files are owned by the nncentral account. The main Oracle Communications Session Delivery Manager process has to run as a sudo user in order to have access to port 162.
Add the NNCentral Group and NNCentral User Account
The nncentral group and user account must be added to administer Oracle Communications Session Delivery Manager server operations on your Linux server.
Specify NNCentral User Privileges
You must specify limited privileges for an NNCentral user on the Linux server, so this user can administer Oracle Communications Session Delivery Manager operations on the server.
You must use
visudo
to make edits to the sudoer configuration file.
This file can only be edited using Linux visual text editor (vi editor) commands.
